Chazman's avatar
Chazman
R8000 WAN not updating when the modem updates the address from ISP
WAN is not updating with the modem WAN after update from ISP.  The router has to be reset for the update to take place.  Genie shows Internet connection is GOOD when there is no Internet.  As you can...
  • JamesGL's avatar
    Dec 01, 2016
    Hi Chazman,
    Try reloading the previous firmware of the router and reset. Observe if still the same problem.
    JamesGL
    Community Team
