Toan
Jul 23, 2017Aspirant
R8000 wifi scheduler not working
I have a Nighthawk X6 R8000 with Firmware Version: V1.0.3.46_1.1.32 After the recent firmware upgrade the Wifi scheduler no longer works. Below are the steps I took to troubleshoot the problem: ...
- Jul 27, 2017
Hi Toan,
Check the time of the router, make sure it is same as your time. You can check it under schedule.
Toan
Jul 28, 2017Aspirant
It's working correctly after the time zone change as you indicated.
Thanks,
JamesGL
Aug 01, 2017NETGEAR Employee Retired
Hi Toan,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
