Nighthawknoob
Jun 17, 2016Follower
R8000 will NOT register to Readycloud
Hello, So I am trying to register my R8000 router (frimware version V1.0.3.4_1.1.2) through the admin page but I get the error message: "Registration failed. Please check your user name and pass...
- Jul 15, 2016
Hi, the message I got was
Registration failed. Please check your user name and password and try again.
By coincident I found a comment in a forum that ReadyCloud do not accept certain characters in the MyNETGEAR password. I removed a "&" character and just used letters and digits in my password.
After that it worked!
So Netgear should definitely corrct the bugs in their software. There is a lot of people out there struggling with this issue.
Thanks for your replay
JamesGL
Jul 06, 2016NETGEAR Employee Retired
Hi All,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
mwall
Jul 14, 2016Tutor
Unfortunately it did not help....Very complicated and error prone routers...
- JamesGLJul 14, 2016NETGEAR Employee Retired
Hi mwall,
Are you having problems with ReadyCloud as well? What is the exact error message or scenario that you are experiencing with ReadyCloud.
- mwallJul 15, 2016Tutor
- JamesGLJul 17, 2016NETGEAR Employee Retired
Hi mwall,
Thank you for the update. Good to know it is working now.
