pjd813
Jun 06, 2022Guide
R8000 wired speed lower that speed from modem
Spectrum just upgraded my speed from 200 to 400. I see that I am getting well over 400 when I connect the laptop by Ethernet to the modem. When I connect the laptop to the R8000 router, however, I ge...
Jun 08, 2022Guru - Experienced User
Please post a copy and paste of the modems connection status page.
How was FW loaded on the router? Manually?
What browser are you using?
pjd813
Jun 09, 2022Guide
Hi,
I thought that I pasted a copy of the modem status page below. If that's not it can you let me know which screen I need to send? Maybe a picture example of the right page?
I downloaded and installed the FW from the web UI.
I'm using Firefox on my mac, Safari on the ipad and Edge from a windows laptop. The results are consistent across all three.
I tested the speed using the SeedTest app on my iPad, Speedtest from my ISP and Speedtest from the Netgear Web UI on the QoS screen. The speed coming out of the modem is rock solid consistent at almost 500 while the speed from the router varies from 69 to 250 from moment to moment. Never higher than that. Thanks.....
Pete D.
- FURRYe38Jun 09, 2022Guru - Experienced User
The connection status page would be under the basic tab.
Got a neighbor, friend or family member near by that you could take the router too and see if the problem follows? If it does then probably the router has gone bad may need replacing.
