Retired_Member
Aug 07, 2016R8000 Wireless is off
I have a R8000 wifi router with firmware V1.0.3.4_1.1.2 and the wireless is off from the web UI and the genie app. However the LED on the router are on. I am unable to access wi-fi eventho the wifi s...
- Retired_MemberAug 08, 2016
Verify you're using correct AC adapter.
Retired_Member
Aug 07, 2016The wifi led is solid whiteand the wifi leds are solid white. Called Netgear support. Did reset, power off. Then power on. The wifi came back temporarly. Now the router is rebooting on its own or when it is not rebooting the wifi led are solid white and I can't see the ssid when I scan for them. Support can't do anything. They believe it is a faulty hardware. (it was purchased in 2104).
Retired_Member
Aug 08, 2016Verify you're using correct AC adapter.
- Retired_MemberAug 10, 2016
Bingo. I was using the wrong AC adapter. I have many netgear products and in fact I was not using the right AC adapter. Thanks Guys for all your help. I really appreciated.
- Retired_MemberAug 11, 2016
You're Welcome!
