bock41's avatar
bock41
R8000 won't go to factory settings
After pushing the reset button and holding for 7 sec. the r8000 restarts, but nothing has changed. No factory settings are restored.   What can be the issuue/solution?   Thx i.a.!
  • JamesGL's avatar
    Dec 03, 2017
    Hi bock41,
    Press it until the power turns amber. Have it pressed about 10-15 secs.
