vdotmatrix
Dec 20, 2018Guide
R8000 WPA-key for HP6400 printer network setup
I updated the firmware on our router. It changed all the names of the 3 channels and now I have to re-add all the home devices to the home network.
the last one is the HP j6400 series printer t...
- Dec 20, 2018
Greetings,
This is the pasword for your wireless network.
Note: The firmware on some older HP printers does not support WPA/WPA2-PSK [AES] and only supports WPA Security [TKIP].
shadowsports
Dec 20, 2018Hero
Greetings,
vdotmatrix
Dec 20, 2018Guide
OKAY!!!
The combination has worked since we got the printer a couple years ago and only when I updated the routers firmware did the issue begin...THANK YOU FOR RESPONDING...I will try again.
- shadowsportsDec 20, 2018Hero
Let us know how you make out.
