PaulGreefhorst
Dec 27, 2023Aspirant
R8000 x6 signal strength contunouslyu dropping
I experience a lot of troubles with my R8000 router. Devices lossing connection; the router often does nt show all connected devices (some device that are working properly are not listed), mostly one...
michaelkenward
Dec 27, 2023Guru - Experienced User
What firmware version do you have on the router?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that sits between this router and the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
PaulGreefhorst
Dec 28, 2023Aspirant
Hi,
Firmware is 1.0.4.84
Modem is cisco epc3940, the router function on this modem is disabeld
- michaelkenwardDec 28, 2023Guru - Experienced User
Hi,
Firmware is 1.0.4.84Modem is cisco epc3940, the router function on this modem is disabeld
How?
If you just turned off the wifi, that does not disable the router.
cisco epc3940 bridge mode - Google Search
- PaulGreefhorstDec 28, 2023Aspirant
Bridge function is disabeld by provider
What does that mean?
Bridge mode = modem only on a modem/router.
If the provider has disabled bridge mode, how have you disabled the router component?
