PaulGreefhorst
Dec 27, 2023Aspirant
R8000 x6 signal strength contunouslyu dropping
I experience a lot of troubles with my R8000 router. Devices lossing connection; the router often does nt show all connected devices (some device that are working properly are not listed), mostly one...
PaulGreefhorst
Dec 28, 2023Aspirant
Hi,
Firmware is 1.0.4.84
Modem is cisco epc3940, the router function on this modem is disabeld
michaelkenward
Dec 28, 2023Guru - Experienced User
PaulGreefhorst wrote:
Hi,
Firmware is 1.0.4.84Modem is cisco epc3940, the router function on this modem is disabeld
How?
If you just turned off the wifi, that does not disable the router.
cisco epc3940 bridge mode - Google Search
- PaulGreefhorstDec 28, 2023Aspirant
Bridge function is disabeld by provider
- michaelkenwardDec 28, 2023Guru - Experienced User
What does that mean?
Bridge mode = modem only on a modem/router.
If the provider has disabled bridge mode, how have you disabled the router component?
Sorry, the bridge mode in enabled on my modem, so the wifi and router functions of themodem are disabeld.
