JimTheGreek
Oct 03, 2019Tutor
R8000
I used to think NETGEAR was the best. My last Netgear (can’t recall m/n) was several years back, now I returned to old trusted, except I have my doubts! The install wasn’t the smoothest, the circle a...
- Oct 11, 2019
Well, I guess I AM a masechist, I traded that one in for the Nighthawk AX8 and I love it.
Zero installation issues, excellent signal in the entire house, good speed. I think this is a keeper!
I think this will be last post other than replies to this, unless I have issues with this one too, but I don't expect any!
Thank you all for your input!
Cheers!
Or as we say in Greece, Opa!
myersw
Oct 03, 2019Master
Put back in box and return. Get different vendor. I like you used to think Netgear was the best. A r8000 and r8000p fight with firmware proved to me otherwise.
JimTheGreek
Oct 03, 2019Tutor
Can you recommend one for a large home coverage?
Thanks!
Thanks!
- myerswOct 04, 2019Master
Eero for a mesh would probably work fine.
- JimTheGreekOct 11, 2019Tutor
Cheers!
