Ahmedyounes
Dec 01, 2019Aspirant
R8000
Is there any way I can add bridge mode to this model ?
- Dec 06, 2019
> > An R8000 is a router, not a modem+router.
> Thanks for stating the obvious! [...]
If it's so obvious to everyone that the OP has a router, and not a
modem+router, then what's the point in posting irrelevant (and
erroneous) "information" about some "Modem/Router's"?> [...] why don't you try being nice [...]
How "nice" is posting irrelevant (and erroneous) "information" here?
I fail to see how it would it be "nice" to leave such nonsense
uncorrected, to mislead the OP (and other, future readers who might be
unfortunate enough to stumble onto this thread).
IrvSp
Dec 05, 2019Master
Modem/Router's can be bridged, and it means basically turning off the Wireless on the unit so it doesn't interfer with the router's wifi that plugs into it.
Now, how about asking a question about a problem you are having and how to solve it? Suspect you want to plug the R8000 into another Router as an Extender, or the other way around? If so, the answer should be in the R8000 manual you can get on the Support tab.
Ahmedyounes
Dec 06, 2019Aspirant
You are rude
