MD2006
Jun 17, 2021Follower
R8000
When I log into the router it says wifi is ok.
When I use netgenie it says wifi is not setup, why.
What do I need to do?
Thank you.
Thank you.
1 Reply
MD2006 wrote:
When I use netgenie it says wifi is not setup, why.What's that?
The "genie" could be one of several things, the browser interface, a Windows or Mac program for a PC, or a mobile Android/iThing app. Netgear labels them all as genies. Which are you using?
MD2006 wrote:
When I log into the router it says wifi is ok.Login to what? Wifi? Browser graphical user interface?
How? Wired? Wifi?
