correeriley's avatar
correeriley
Follower
Dec 23, 2021
R8000
Have had about 4 years now. All of a sudden my wifi stopped working but I am hardwired still. Does the wifi just go out in these and is it time to replace?
  • plemans's avatar
    A little more details help.
    1. what are the wifi led's on the router showing? (color/blinking/on or off/etc)
    2. what firmware is on the router?
    3. did the wifi on/off button get hit? push and hold it for 2 seconds
    4. For some reason did the ssid broadcast get disabled? you can check in the settings
    • wcalifas's avatar
      wcalifas
      Prodigy
      try unplugging your router for 20 seconds and back on and see if the wifi comes back. If not I would try to do a hard reset by pressing the reset pinhole with a paper clip for 30 seconds while its powered on. It will put it back to factory default, see if one of those 2 options brings back the wifi.
