baklol
Jul 16, 2022Aspirant
R8000
I am not able to see my 2.4ghz under "networks' on any of my devices, how to fix this please
Jul 16, 2022Guru - Experienced User
Is Smart Connect enabled on the router.
Do you see the 2.4Ghz LED ON or blinkining any top of the router?
- baklolJul 16, 2022AspirantHi yes the router 2.4ghz light is on and shows as connected and working but won’t show up under networks. It should show up as Netgear 2.4ghz isn’t it ? Just like Netgear 5ghz
- michaelkenwardJul 17, 2022Guru - Experienced User
baklol wrote:
It should show up as Netgear 2.4ghz isn’t it ? Just like Netgear 5ghzSome devices can combine 2.4 GHz and 5 GHz into a single SSID.
- plemansJul 17, 2022Guru - Experienced User
If you have smart connect enabled, the 2.4ghz and 2x 5ghz bands will all show up under one ssid. (one network)
Devices will switch between the networks as needed.
You can disable it if you want so you can separate out the 3x networks.
