Shibumikg
Aug 11, 2022Aspirant
R8000+c6300 can these work together?
I recently moved the person I'm living with has a Nighthawk X6 router I brought a Netgear c6300 with me there's a separate Cottage off the property where the connection does not actually reach what I'...
- Aug 11, 2022
You could not use the C series modem then.
Aug 11, 2022Guru - Experienced User
Yes. However since both are routers, I recommend that you configure the C6300 for modem mode only, then connect the R8000 to the C series modem and this will work well for you.
https://kb.netgear.com/27191/How-do-I-set-my-NETGEAR-cable-modem-router-to-function-as-a-modem-only
