Shibumikg
Aug 11, 2022Aspirant
R8000+c6300 can these work together?
I recently moved the person I'm living with has a Nighthawk X6 router I brought a Netgear c6300 with me there's a separate Cottage off the property where the connection does not actually reach what I'...
- Aug 11, 2022
You could not use the C series modem then.
Shibumikg
OK cool - they will be in separate locations. I more need an extender/repeater (?). The way the property is set up there is a main house and a cottage/Guest House off to the side where I am staying. The connection range does not reach that far with the modem router current setup. Can I use the c6300 that I brought with me as an extender or a second connection? Or is that a service provider issue?
Appreciate the help!
Just moved to the islands surrounded by concrete and blackout spots, oy vey!!!
Aug 11, 2022Guru - Experienced User
The C series modem can only work in gateway mode or modem only mode. Modem only mode shuts off the router and all wifi radios.
Will you still be using the modem to connect to your ISP services?
You'll need a ethernet cable (CAT6) to connect the modem to the R8000 router.
- ShibumikgAug 11, 2022AspirantNo as she has a aries modem connected to the nighthawk as router. She has a Amped SR extender for the cottage. Currently not working - saying no internet - I think I have to rerun the wizard for that but wanted to know if I had alternatives. Thanks for the assistance. Any additional advice welcome!
- FURRYe38Aug 11, 2022Guru - Experienced User
