PeterMarc
Mar 28, 2023Initiate
R8000P - Can't add a DHCP reservation for any MAC (Invalid MAC!)
Router R8000P,
Firmware: V1.4.4.94_1.3.56
OS: Win 11 pro / Win 10 pro
Web browser: Firefox
State of router: After firmware reset/ with or without Armor enabled (no difference).
Tested for:...
- Jun 05, 2023
FYI, the beta fixes the IP address reservation issue.
corbin
Apr 28, 2023Aspirant
Hi, I'm having the same problem with invalid MAC errors on my R7960P when trying to add a reservation. Can you send please
Dr_Dino
Apr 30, 2023Aspirant
I am having the same issue...
- electric451May 04, 2023Aspirant
I have this problem too. Are you able to help?
- FURRYe38May 04, 2023Guru - Experienced User
PM Sent
- ACMilan1899May 13, 2023GuideWhat is the solution?
- FURRYe38May 13, 2023Guru - Experienced User
- naughtyowlMay 26, 2023Aspirant
Hello - I'm seeing the same issue "invalid MAC address" on V1.4.4.94_1.3.56 / R8000 P. Appreciate any suggestions.
Thanks.
- FURRYe38May 26, 2023Guru - Experienced User
PM Sent.
Thanks.
