PeterMarc
Mar 28, 2023Initiate
R8000P - Can't add a DHCP reservation for any MAC (Invalid MAC!)
Router R8000P,
Firmware: V1.4.4.94_1.3.56
OS: Win 11 pro / Win 10 pro
Web browser: Firefox
State of router: After firmware reset/ with or without Armor enabled (no difference).
Tested for:...
- Jun 05, 2023
FYI, the beta fixes the IP address reservation issue.
naughtyowl
Jun 04, 2023Aspirant
I went back 1 version and was able to do the IP reservation without the invalid MAC error.
Jun 05, 2023Guru - Experienced User
Did you not try the beta I sent you?
- naughtyowlJun 05, 2023AspirantCorrect - I did not end up using the patch.
