PeterMarc
Mar 28, 2023Initiate
R8000P - Can't add a DHCP reservation for any MAC (Invalid MAC!)
Router R8000P,
Firmware: V1.4.4.94_1.3.56
OS: Win 11 pro / Win 10 pro
Web browser: Firefox
State of router: After firmware reset/ with or without Armor enabled (no difference).
Tested for:...
- Jun 05, 2023
FYI, the beta fixes the IP address reservation issue.
Sep 10, 2023Guru - Experienced User
Did you not get the beta that fixed this?
PeterMarc wrote:
I apologize for not participating in the discussion, but I've bought a different router and the one this thread is about is sitting on a shelf. I didn't have the energy or time to wait for a solution. I will definitely not buy any more products from this company.
Take care, best regards.
Peter
GISGuy76
Sep 10, 2023Tutor
I don't think there is a beta release due to the lack of someone actually posting a link to it. Netgear really needs to post a new firmware release that actually corrects the issue. They are well aware of this issue and have chosen to ignore it for now.
- FURRYe38Sep 10, 2023Guru - Experienced User
There IS beta FW that fixes this. Been out for a while now. Ya I agree, NG should just release it in the next FW update. If there will be one. 🙄
- GISGuy76Sep 10, 2023TutorDo you have a direct link to the beta version of the firmware that you can send me? Thanks.
- will40Sep 12, 2023Aspirant
Can you PM to me as well?
Thank you
- xlonguyenxSep 15, 2023Aspirant
Can you also sent me the update firmware to fix address reservation issue
