Soldermonkey
Oct 24, 2021Aspirant
R8000P - DNS issues after firmware update
For some unknown reason, the automatic firmware update did not work on my R8000P router, and I found that I was one version behind at 1.4.1.68. So I manually updated to 1.4.2.84. After the update, ...
jtdarlington
Dec 11, 2021Tutor
Can confirm that downgrading to V1.4.1.68_1.3.28 "fixes" the DNS issue. Fortunately, the security flaw V1.4.2.84_1.3.42 is supposed to fix requires access to the local LAN, so I guess we'll just have to live with that for now. (Of course, anyone who follows INFOSEC news knows there are ways around the "local LAN" issue. Just make sure everyone in your household/office knows to browse safely.)
kerryland
Dec 11, 2021Guide
My plan is to install a pi-hole and use that for DNS. My current workaround of defining DNS hosts on each machine is silly.
- mclaurentiuJan 15, 2022Tutor
Any luck with this, Netgear? I've had several attempts to add this comment... This is my first and will be my last Netgear device. It would appear you cannot afford to hire reasonable talent. I mean, seriously, DNS issues in a router ?! You're kidding me right? Sounds like piston misfires in an engine. Would you buy a car from that manufacturer ?
Fix it !
