Soldermonkey
Oct 24, 2021Aspirant
R8000P - DNS issues after firmware update
For some unknown reason, the automatic firmware update did not work on my R8000P router, and I found that I was one version behind at 1.4.1.68. So I manually updated to 1.4.2.84. After the update, ...
kerryland
Dec 11, 2021Guide
My plan is to install a pi-hole and use that for DNS. My current workaround of defining DNS hosts on each machine is silly.
Dec 11, 2021Guru - Experienced User
kerryland Pihole works pretty nice. I've got one but its running in a docker container on my server. Love how much it blocks.
- mclaurentiuJan 15, 2022Tutor
Any luck with this, Netgear? I've had several attempts to add this comment... This is my first and will be my last Netgear device. It would appear you cannot afford to hire reasonable talent. I mean, seriously, DNS issues in a router ?! You're kidding me right? Sounds like piston misfires in an engine. Would you buy a car from that manufacturer ?
Fix it !
