Soldermonkey
Oct 24, 2021Aspirant
R8000P - DNS issues after firmware update
For some unknown reason, the automatic firmware update did not work on my R8000P router, and I found that I was one version behind at 1.4.1.68. So I manually updated to 1.4.2.84. After the update, ...
GapJack27
Apr 02, 2022Tutor
Several more months on and still no fix or new firmware update? For real? They can't even make a firmware version available that's between 1.4.2.68 and 1.4.2.84? This is not good. Is this model officially end of life and there will never be another firmware update or hotfix? Bueller?
Apr 02, 2022Guru - Experienced User
What do you mean between .68 and .84? There was probably nothing made or developed for release between those versions so if there was, was not mented for public use.
For now, users should keep to v.68 or .v62 for now. Fixes and FW development doesn't happen over night.
- GapJack27Apr 02, 2022Tutor68 came out over a year ago. 84 came out 6 months ago and the DNS issues have been getting reported since then. I don’t think 6 months = overnight or that it is unreasonable to expect at least some sort of hot fix to be made available within 6 months, especially when the issue directly impacts your ability to use the internet, which is kind of the main purpose of having a router. Having to use an insecure firmware version for 6 months as the only solution to continue to use this hardware is not a good look.
- FURRYe38Apr 02, 2022Guru - Experienced User
Well it is what it is. I've seen some mfrs take 9 mths to a year to come out with new FW updates. You'll have to be patient.
- canam2020Apr 19, 2022Aspirant
Downloaded new firmware to V1.0.4.84-10.1.84 and now have the same issue on all three devices. How do I get the "old" version installed?
I am a relative novice when it comes to wireless router set up.
- FURRYe38Apr 19, 2022Guru - Experienced User
Did you try this version of FW?
Users can try enabling IPv6 to see if this corrects the DNS problem...
