Kernel009's avatar
Kernel009
R8000P - most stable firmware?
Hi all... I've had this router since 2018 so it could be age causing this but recently the router seems to be locking up.  Problem is, I did a firmware upgrade recently and didn't write down what the old version which was working great.  I just figured I'd upgrade because of "security fixes".
So the quesation is, what is the most stable version of the firmware for this model?
Thanks.
  • Apologies for the delayed reply.
    This worked OK for a week or so, then things started acting up again.  Unfortunately I couldn't continue with the recurring issues because I work from home, so I ended up replacing it with a mesh system.  It was 6 years old so perhaps it was simply dying a slow death.  Regardless, I have not had any issues since replacing it.
    Thanks for the assistance - wish I didn't have to replace it but sometimes that's the only solution.
  • plemans's avatar
    What version did you install? Or is on it?
    Anytime I have issues after a firmware change, I factory reset and do a manual reinstall (installing without using a backup) before downgrading if there's issues. Sometimes old settings can cause issues and the firmware can help fix that.
    I'd try that first.
    • Kernel009's avatar
      Kernel009
      The one I downgraded to is 1.4.1.68_1.3.28.  However, I just experienced the same issue again out of the blue and it was only fixed with a reboot.  I'm going to try some others, but wondering if this thing is just close to giving up the ghost.
      • FURRYe38's avatar
        Any progress on this?
