tjvrulz
May 20, 2021Tutor
R8000P - Random bandwidth drop on devices connected over WiFi
I have a Netgear Nighthawk R8000P running V1.4.1.68_1.3.28 . Recently my WiFi connected devices (both on 2.4G and 5G) are randomly suffering from loss of bandwidth. The router is currently in "Router...
- May 20, 2021
Try installing version 1.4.1.42 of the firmware to the router. Then do a factory reset and clean install (by clean, don't use a backup). then disable auto updates and try it for a bit .
May 20, 2021Guru - Experienced User
