tjvrulz
May 20, 2021Tutor
R8000P - Random bandwidth drop on devices connected over WiFi
I have a Netgear Nighthawk R8000P running V1.4.1.68_1.3.28 . Recently my WiFi connected devices (both on 2.4G and 5G) are randomly suffering from loss of bandwidth. The router is currently in "Router...
- May 20, 2021
Try installing version 1.4.1.42 of the firmware to the router. Then do a factory reset and clean install (by clean, don't use a backup). then disable auto updates and try it for a bit .
May 20, 2021Guru - Experienced User
tjvrulz
May 20, 2021Tutor
Thanks for your suggestion plemans . I found the 1.4.1.42_1.3.4 firmware on the router support page and have installed it. WIll monitor it for 2 to 3 days and see if this resolves the issue.
- bchamp62May 20, 2021AspirantYeah I only saw the last version 68, still searching. Let’s know how you get on
- RavipatiMay 24, 2021Aspirant
bchamp62 wrote:
Yeah I only saw the last version 68, still searching. Let’s know how you get onhttps://www.downloads.netgear.com/files/GDC/R8000P/R8000P-V1.4.1.42_1.3.4.zip
