JDHoward's avatar
JDHoward
Follower
May 02, 2022
R8000P - randomly losing configuration?
I sdfsdsddfsdfdfdfsdfasdfI have a R8000P WiFi Extender.  I configured it a year ago, and it has worked great until I powered it down last night as I do every month.  This morning it lost its configuration and would not connect to my Router!  I had to reconfigure the range extender from scratch.  Is this a known problem?  I hope I don't have to do this again!  Thakns!
  • FURRYe38's avatar
  • plemans's avatar
    The R8000P isn't a wifi extender.
    Its a router.
    What extender do you have?
    What router do you have?
    Are you setting it up using wps or using the installation assistant?
