Bluetyler63
Jul 31, 2023Aspirant
R8000P - USB HDD storage no longer accessible over network
Hello all, I have a HDD attached to my R8000P router via USB 3.0 port that while still discoverable by my TV, BD player and other network devices, I can no longer access the drive to edit files v...
michaelkenward
Jul 31, 2023Guru - Experienced User
Bluetyler63 wrote:
I have a HDD attached to my R8000P router via USB 3.0 port that while still discoverable by my TV, BD player and other network devices, I can no longer access the drive to edit files via my Android phone app, nor PC over wifi.
How were you accessing these files?
ReadyCloud?
Support for ReadyCLOUD feature ends spring 2023 | Answer | NETGEAR Support
- Bluetyler63Jul 31, 2023Aspirant
Hi, thanks for the prompt reply.
I was accessing through 'Myfiles' android app (samsung) which allowed me to add and delete files over wifi connection. I could easily find the drive on the router by selecting.
Network storage > 'Add network storage' > it previously had the following options to select as the next step
- FTP server
- SFTP server
-Network drive (SMB)
I select the Network drive option and it would find the Readyshare USB storage drive and I would logon via the router password.
this has now changed to
- FTP server
- SFTP server
-Network drive (SMBv2/SMBv3)
On selecting the latter, it comes up with the drive (SMB) READYSHARE 192.168.1.1:445 but it rejects the logon. I usethe same credentials as the router. This has always worked previously
I tried another app that allows you "add a remote location", then select SMB and manually input 192.168.1.1:445. I even tried using the option of 'SMBv1' rather than 'Automatic' but I still get an error message "Could not connect"
As mentioned in the OP. Once I'm connected to the storage it is an easy method of transferring files to the HDD connected to the router and being able to access media files on other devices such a Smart TV's etc.
Thank in advance for any addtional guidance.
- schumakuJul 31, 2023Guru - Experienced User
Does the R8000P support SMB 2.0 and 3.0 as referred to in this old thread, and is it enabled?
- Bluetyler63Aug 01, 2023Aspirant
Hi schumaku,
Thanks for the reply. I don't think it does. I'm not seeing the SMB options in the USB Functions (Advanced) section when I logon to the R8000p. So it looks as its using the older SMBv1 protocol version?
As mentioned in the OP, it was connecting ok last week.
- schumakuAug 01, 2023Guru - Experienced User
- FTP server
- SFTP server
On selecting the latter, it comes up with the drive (SMB) READYSHARE 192.168.1.1:445 but it rejects the logon. I use the same credentials as the router. This has always worked previously
There it is: Samsung decided no longer supporting SMBv1 for the storage access - what the community know-how says it's the only SMB protocol available on your Nighthawk router model. And yes, the R8000P is just about six years old. Even after tis time, there would be room for enhancements - better late than never.
Not nagging, wanted to open the Samsung My File (also previously workable on my Galaxy Tab A7 aka. SM-T505 tablet.). Just a brief message: This device is no longer eligible for this App. Despite it's Build Number : T505XXU4CWD2 Android version : S(Android 12) Release Date : 2023-04-26 Security patch level : 2023-03-01. Nothing hopelessly outdated.
- Bluetyler63Aug 02, 2023Aspirant
Thanks again schumaku,
Disappointing. I purchased the R8000P in 2020 with an expectation it would be good for at least 5 years, the ability to plug in USB storage was one of the reasons for selecting this model. I would have thought a firmware update to support the newer SMB protocols would have been issued. Would Netgear do this? I suppose the fact they haven’t with the last update makes it unlikely.
