Bluetyler63
Jul 31, 2023Aspirant
R8000P - USB HDD storage no longer accessible over network
Hello all, I have a HDD attached to my R8000P router via USB 3.0 port that while still discoverable by my TV, BD player and other network devices, I can no longer access the drive to edit files v...
Bluetyler63
Hi, thanks for the prompt reply.
I was accessing through 'Myfiles' android app (samsung) which allowed me to add and delete files over wifi connection. I could easily find the drive on the router by selecting.
Network storage > 'Add network storage' > it previously had the following options to select as the next step
- FTP server
- SFTP server
-Network drive (SMB)
I select the Network drive option and it would find the Readyshare USB storage drive and I would logon via the router password.
this has now changed to
- FTP server
- SFTP server
-Network drive (SMBv2/SMBv3)
On selecting the latter, it comes up with the drive (SMB) READYSHARE 192.168.1.1:445 but it rejects the logon. I usethe same credentials as the router. This has always worked previously
I tried another app that allows you "add a remote location", then select SMB and manually input 192.168.1.1:445. I even tried using the option of 'SMBv1' rather than 'Automatic' but I still get an error message "Could not connect"
As mentioned in the OP. Once I'm connected to the storage it is an easy method of transferring files to the HDD connected to the router and being able to access media files on other devices such a Smart TV's etc.
Thank in advance for any addtional guidance.
schumaku
Jul 31, 2023Guru - Experienced User
Does the R8000P support SMB 2.0 and 3.0 as referred to in this old thread, and is it enabled?
- Bluetyler63Aug 01, 2023Aspirant
Hi schumaku,
Thanks for the reply. I don't think it does. I'm not seeing the SMB options in the USB Functions (Advanced) section when I logon to the R8000p. So it looks as its using the older SMBv1 protocol version?
As mentioned in the OP, it was connecting ok last week.
- FURRYe38Aug 01, 2023Guru - Experienced User
I know from using my NAS that has older SMBv1, I have to enable SMBv1 on my Windows PCs for them to keep access.
