juandll
Sep 13, 2021Follower
R8000P - WIFI Internet speed problem
Bad internet speed using wifi, i can stand in front of the router and i always get 400-500mb, when i use ethernet i got 1gb/s, this problem both happened with another router of netgear and i decide t...
Sep 13, 2021Guru - Experienced User
what speeds do you think you should get?
Getting 400mbps out of the R8000P is pretty darned quick for it.
Wireless speeds are very over rated and people have a misunderstanding of them.
I'd highly recommend reading both this article on wifi speed misunderstandings and then a tested review of the r8000P
https://www.duckware.com/tech/wifi-in-the-us.html
