Ravsir
Mar 21, 2022Tutor
R8000P Access Control and DHCP issues
Hi Community, I purchased an R8000P for the ability to connect a large number of WiFi devices at once, upgrading from a D7800. I've got to say I'm less than impressed with the upgrade to date with ...
Mar 22, 2022Guru - Experienced User
I recommend downgrading FW to v.62. Seems to be the best version currently.
- RavsirMar 23, 2022Tutor
Cheers for the feedback, I'll try and locate a copy of 62 and downgrade. Will report back with progress once I've had it running a week or so.
- michaelkenwardMar 24, 2022Guru - Experienced User
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have firmware for your device.How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
- RavsirMay 09, 2022TutorI ended up downgrading to v62 and have monitored for a couple of weeks. No help unfortunately and somehow the router bypassed the "do not automatically update" checkbox and updated itself. I ended up going back to the ds7800 and surprise, surprise it actually manages IP allocations properly! This r8000p is garbage where it counts. I'm just unsure if it's my unit or the firmware on all of them? Does anyone else have trouble with devices being allocated a specific IP address across an extended network? (Through an ex7700) my ds7800 had no issues recognising a device in the IP list and allocating the right IP, even when it connects through the ex7700 and presents with the virtual prefix 3 octects. Meanwhile the r8000p just keeps chewing up IPs everytime the device disconnects and reconnects. I'd keep the old ds7800 but the triband extender chews time on the only available 5ghz radio on the ds7800. Such a disapponting group of products that should just work together, but just don't...
