JimC57
Mar 30, 2021Aspirant
R8000p Constantly needs to be rebooted, and password resets are the only way to get into the router
This router is turning out to be the worst purchase I ever made, the router regularly needs to be reset, the Android app is useless. I have had the incoming signal checked thinking that maybe the iss...
JimC57
Sep 23, 2021Aspirant
Yes, did not fix this issue, it is now presenting this issue multiple times aday, ISP has installed monitoring on my connection, but does not show drops in service, nor is my phone service dropping. I had to stop recommendating this product to my familt and customers as every installation has experienced this issue.
JimC57
I shouldhave mentioned, it drops all connections wired or wifi, will not let me log in after this happens to check the log files and need to reboot router to get it to work properly. Factory reset weekly and have latest FW. Manually reconfigure settings each factory reset
- JimC57Sep 23, 2021Aspirant
dropped again today, also the wireless app does nothing but craches, modile data is off on my android phone. log file did show internet disconnected and 6 minutes later reconneted so a called my isp and they said the tracking they has on my modem did not show an issue so i'm stuck with a frustrating issue. Since Netgear can't help, do I replace all my netgear equipment with a competitor, I have used nothing but netgear for 30 years. I can't believe with the amount of reports fro users with this router that Netgear fails to help I wonder how much bottom line has been effected by loosing customer base. I would appreciate some guidance at the very least.
- JimC57Jan 13, 2022Aspirant
Still dropping, the router looses internet both wired and wifi, but comes back up somestimes after about 5 minutes, ISP does not see any drops in service, my router logs has information on the drops see bottom of log file for Wednesday, Dec 31,1969 19:00:00. when router comes back up sometimes it does not get the external IP address from the modem, after 2 to 3 reboots it picks up. If I connect my laptop directly to the modem it shows ip address and connected since the last time I reset the modem.
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:49:29
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:49:15
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:49:01
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:48:47
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:48:33
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:48:20
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:48:06
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:47:52
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:47:38
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:47:24
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:47:11
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:46:57
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:46:43
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:46:29
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:46:15
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:46:02
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:45:48
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:45:34
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:45:20
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:45:06
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:44:52
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:44:38
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:44:24
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:44:11
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:43:57
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:43:43
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:43:29
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:43:15
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:43:02
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:42:48
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:42:34
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:42:20
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:42:06
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:41:53
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:41:39
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:41:25
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:41:11
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:40:57
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 21:40:44
[DHCP IP Wednesday, Jan 12,2022 21:40:30
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 20:34:34
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 20:34:22
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 20:34:09
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 20:33:58
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 20:33:44
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 20:33:32
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 20:33:19
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 20:33:06
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 20:32:55
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 20:32:42
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 20:32:28
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 20:32:15
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 20:32:01
[DHCP IP: (192.168.1.4)] to MAC address 38:14:28:70:83:02, Wednesday, Jan 12,2022 20:31:49
