MAGA_FJB's avatar
MAGA_FJB
R8000P "Couldn't connect to this network" when security enabled
R8000P Firmware R8000P-V1.4.2.84_1.3.42 Windows 10 Ethernet connected None of my devices connet (give subject error) if wifi security is enabled.   Steps I have taken: 1.  Complete reset of devi...
  • FURRYe38's avatar
    The R series routers don't support actual MESH. I presume you set up the other system as a router and extender or repeater kind of configuration with two R8000Ps.
    Ya, sent this unit back.
