MAGA_FJB
Feb 05, 2022Aspirant
R8000P "Couldn't connect to this network" when security enabled
R8000P Firmware R8000P-V1.4.2.84_1.3.42 Windows 10 Ethernet connected None of my devices connet (give subject error) if wifi security is enabled. Steps I have taken: 1. Complete reset of devi...
- Feb 05, 2022
The R series routers don't support actual MESH. I presume you set up the other system as a router and extender or repeater kind of configuration with two R8000Ps.
Ya, sent this unit back.
MAGA_FJB
Cellphones, laptops. No apple devices.
They all work well with the AC1900 with wpa-aes. I am trying to upgrade my network but this router just isn't working right.
Feb 05, 2022Guru - Experienced User
If you've tried other versions of FW, even 1st version, factory set and no Armor or access controls configured and wifi devices are not getting connected with WPA2 and AES to the internet, maybe time for a new router.
- MAGA_FJBFeb 05, 2022Aspirant
Internet provider is CenturyLink through a Actiontec C3000A Modem. Wifi is disabled on the ActionTec. R8000P is the only thing plugged into the C3000A.
I plugged Engenius Access Port into the R8000P and that is how my wireless devices are connecting. I had hoped to move the access port and use two R8000P in a mesh configuration, but now I am wondering if I should do that.
Very disappointed I cannot connect securely. Is there an encryption board that may have gone out?{Internet} -- C3000A --- R8000P -- Engenius Access point.
Router is issuing IP addresses as it should.
RE: "If you've tried other versions of FW, even 1st version, factory set and no Armor or access controls configured and wifi devices are not getting connected with WPA2 and AES to the internet, maybe time for a new router. "
I wanted to establish a mesh network. Maybe not, now.
Router is refurbished and purchased through Amazon. I guess I will have to send it back.- FURRYe38Feb 05, 2022Guru - Experienced User
Be sure the ISP modem is configured for bridge mode. However not sure if this would correct the issue on the NG router.
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers?_ga=2.190834155.1964120923.1641394007-133989108.1641394007
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/24104/How-do-I-change-my-Nighthawk-router-to-AP-mode-after-I-ve-already-run-setupTry option 3 with the ISP modem to see if devices can connec thru the 8000 in AP mode. If still same problem, then send the R8000 back.
ISP modem is configured as Modem only.
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.Modem is in modem only mode. R8000P is in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers?_ga=2.190834155.1964120923.1641394007-133989108....
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-routerAll modem wifi radios are already disabled. Not seeing how the pass-through IP address would change anything of the problem with connecting with R8000P wireless.
https://kb.netgear.com/24104/How-do-I-change-my-Nighthawk-router-to-AP-mode-after-I-ve-already-run-s...Try option 3 with the ISP modem to see if devices can connec thru the 8000 in AP mode. If still same problem, then send the R8000 back.
Option 3 -- cannot connect through the R8000P in Access Point mode.Yeah, I'm afraid I have to send it back.
I helped a friend configure his two R8000Ps in a mesh configuration. I was quite impressed with how it worked. Now I am saddened to read all these stories of the wireless dropping or not connecting. Thanks so much, Furry.
