abhinavbanerjee
Jan 03, 2022Aspirant
R8000P DHCP issue
The systems connected to router cannot connect to intenet using DHCP from router but works fine after assigning manual IP. Unchecked the option of Use Router as DHCP Server and rebooted. Again check...
Jan 03, 2022Guru - Experienced User
What modem/gateway do you have from fibrenet?
- abhinavbanerjeeJan 03, 2022Aspirant
Gateway IP Address : 106.51.64.1
- FURRYe38Jan 04, 2022Guru - Experienced User
Please do not post the WAN IP address in a public forum.
What is the brand and model# of the Gateway modem/ONT you using?
abhinavbanerjee
- abhinavbanerjeeJan 04, 2022Aspirant
We have Acton-1000W2A(SM-10) from service provider.
Image attached.
