KFord85
Dec 19, 2021Tutor
R8000P DNS_PROBE_FINISHED_NXDOMAIN after updating Firmware
UGH... So I've searched the forums for this issue (Which is frequent and still unsolved?) but the only choice is to roll back software. Only problem is that I've roled back from .84 down to .42 and ...
Dec 20, 2021Guru - Experienced User
Do you have IPv6 enabled?
Are you currently on the .42 version? And it works?
Its just when you update?
Does it have issues when the extender isn't running?
KFord85
Jan 02, 2022Tutor
plemans,
IPv6 - Disabled
Firmware - went from 1.4.2.84 (newest) down to v1.4.1.68_1.3.28.
I had the router setup to auto update but was noticing that the streaming would pause more often starting around november. About 3 days before writing the post I updated the Extender Firmware (EX8000) and thats when the "DoS attacks" started happening in the log list. They were not DDoS attacks. I cleared the logs, reboot everything multiple times running up and down stairs. Im just wondering where and why its happening. I was getting decent speeds which was great, having to refresh websites i've visited before over and over because my router is acting up- not so much.
IPv6 - Disabled
