miller811
Jan 08, 2022Tutor
R8000P firmware download failure
Still unable to run update, tried multiple browsers, and from IOS AP. IOS AP goes through motions and reboots, but never shows new verison. From firefox I see this and then fails to update new GU...
frstylfreddie
Jan 08, 2022Aspirant
download the firmware update file manually from R8000P Firmware Version 1.4.2.84 | Answer | NETGEAR Support
extract the file, login into the router, go to the advanced tab, adminstration, then router update, click browse and browse to the file and install manually. I couldn't get the auto check and update to work, but manual install worked fine and confirmed new firmware version installed.
miller811
Jan 09, 2022Tutor
Thanks for the information. Downloaded the file, on the fence about attempting to manaul upgrade. Two work from home user. (my wife and I). Really can't afford to brick the device, may try over next weekend.
- plemansJan 09, 2022Guru - Experienced User
If you do try it, good luck!
