master_mike
Mar 07, 2020Initiate
R8000P Firmware Update Issue
I logged into my router via a desktop computer that is wired to the router. Using the advanced admin menu I clicked the button to check for a firmware update. It said "No new firmware version availab...
- Mar 07, 2020
Greetings,
I upgraded to 1.4.1.50 manually yesterday.
Do not use automatic check and update. Its unreliable and almost as bad as trying to update wirelessly.
You were correct to perform the update manually, downloading the file to your local machine connected via ethernet. (best, safest method). Downoad the file and extract it. It has to be unzipped. The file you will use for upgrade has the extension .chk. Do as you did previously, browse to the folder where you unzipped the download from and point it to the file ending in .chk.
Press the upgrade button and wait for the process to finish. The router will reboot when complete.
If you have any more issues, let us know and one of us can assist.
master_mike
Thanks for encouraging me, I tried to manually upgrade the router again. This time I did 2 things differently. First, instead of navigating to the router's web page via its IP address, I used www.routerlogin.net. I also moved the firmware file to the root directory of my computer. IT WORKED!
Thanks again!
shadowsports
Mar 07, 2020Hero
Glad you were successful.
Cheers!
Cheers!
