QQ2222
Oct 31, 2021Aspirant
R8000P firmware update issue
I believe the router is compromised since it has been uploading 100GB data every day for past several days. I was trying to upgrade firmware V1.4.1.50_1.3.10 to the latest one. But there seems no w...
Oct 31, 2021Guru - Experienced User
I'd start by changing your ssid/password.
Then slowly add devices back in.
You might be surprised at whats using data
- QQ2222Nov 03, 2021Aspirant
I did everything you said. Still firmware wont update and DOS attack is happening. This is well know issue as discussed already on the forum. The only solution is replacement.
- plemansNov 03, 2021Guru - Experienced User
I sent you the mod's info on checking on the firmware.
But the removing device fix the data usage?
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R8000p-can-t-update-firmware/td-p/1959938
It is exactly the same issue. A lot of ppl can't update firmware. And the log shows
plemans wrote:I sent you the mod's info on checking on the firmware.
frequent DOS attacks
