eequalsmc2
Oct 01, 2021Initiate
R8000P Firmware Update Issues
Hi is anyone else having issues updating their nighthawk? No matter which way you try to update the firmware it simply will not update. I’ve tried manually updating, using the app, hard reset then ...
Oct 02, 2021Guru - Experienced User
What firmware version are you on?
- eequalsmc2Oct 03, 2021InitiateFirmware version is V1.4.1.50_1.3.10
