eequalsmc2
Oct 01, 2021Initiate
R8000P Firmware Update Issues
Hi is anyone else having issues updating their nighthawk? No matter which way you try to update the firmware it simply will not update. I’ve tried manually updating, using the app, hard reset then ...
jlb4436
Nov 03, 2021Tutor
I am having the same issue. My son bought it for me in May 2020 from Best Buy. Thankfully, he bought the 2 year protection plan. I will be trading this one for a replacement. Hopefully, the replacement will work properly. There are other discussions that show this model has a problem and it seems Customer Support is a real hassle to deal with.
