eequalsmc2
Oct 01, 2021Initiate
R8000P Firmware Update Issues
Hi is anyone else having issues updating their nighthawk? No matter which way you try to update the firmware it simply will not update. I’ve tried manually updating, using the app, hard reset then ...
mhelms1961
Nov 29, 2021Aspirant
Hi All,
I am having the same issue trying to update the firmware. The download did not work, a direct conect with the *.chk file connected to the USB port did not work (it showed the hour glass for about 30 seconds then failed) I have power cycled the router and tried the update with the *.chk file again and still no luck. I wish Netgear would please address this issue and the firmware upgrade message is annoying and I'm worried the router may eventually fail. Current firmware version is V1.4.1.50_1.3.10
Thanks for any help!!!
