cybot
Jul 06, 2021Luminary
R8000p IPv6 6to4 DNS broken
-Firmware Version V1.4.1.68_1.3.28 for quite some time now, the DNS of the IPv6 6to4 setting has been broken. the issue goes back at least several firmware versions. you cannot enter any DNS set...
Oct 19, 2021Guru - Experienced User
Ok, I'd do a power cycle OFF then back ON and check, if problem is still there, try a factory reset and setup from scratch...
