bryd86
Dec 18, 2020Aspirant
R8000P issues with what seems to be buffering
Ive noticed that my router seems to buffer data at some point, either going out or coming in. i have about 19 devices all connected to the router either through wired or wireless connections. the mos...
Dec 18, 2020Guru - Experienced User
Have you tried putting your desktops ip address in the netgear's dmz?
https://kb.netgear.com/1118/How-do-I-configure-a-device-to-be-in-the-DMZ-on-my-NETGEAR-router
bryd86
Yep, tried the DMZ host. It’s like the router is taking a long time to process the traffic and route it to me/send it out
- plemansDec 18, 2020Guru - Experienced User
in the dmz the router is just automatically forwarding it.
I don't know a whole lot about that ont, not sure if it has its own routing capabilities.
could be a double nat issue.
https://kb.netgear.com/30186/What-is-Double-NAT
- bryd86Dec 19, 2020AspirantDefiantly not a double NAT, is it possible that game servers “specifically csgo”, will delay sending/revceiving because of something in my packets? Could they be tagged a certain way or something ....
Is there any service at frontier they offer the prioritize game traffic through the isp itself?there’s a lot of people on the same node in my neighborhood, so much that when I ordered 1g service I rarely got it... I got closer to 500- plemansDec 19, 2020Guru - Experienced User
If you directly connect the gaming device without the router, do you still have the issue?
That's an easy way to tell if the router is causing it or if the isp is causing it.
