George2020
Nov 10, 2020Tutor
R8000p issues
I purchased this router 4 months ago and it recently started having an issue with this unit dropping signal, every time this happens it has to be unplugged and plugged back in. I have noticed this is ...
- Nov 18, 2020
If you're within your warranty, I'd start the rma process with it.
click "mynetgear" at the top. register an account and the device. from there you can start the rma process.
Nov 10, 2020Guru - Experienced User
Is it only wireless dropping?
If only wireless, its it 2.4ghz, 5ghz?
What firmware is on it?
- George2020Nov 10, 2020TutorNo the router just stops all internet services and anything hardwired or wireless stops working. I call my ISP and was assured nothing was wrong On their end. Currently running Version 1.4.1.50
- plemansNov 10, 2020Guru - Experienced User
Try installing version 1.4.1.64 over a hardwired connection.
Then factory reset it and do a clean install. (not from backup)
https://www.netgear.com/support/product/R8000P.aspx#download
- George2020Nov 17, 2020Tutor
I have now factory reset my device 3 different times and tried to install the firmware update 3 different ways and still wont allow me to update, i am also having an issue now with my wifi signals not putting out any internet, but all hardwired devices are working great. SOMEONE PLEASE HELP ME
- plemansNov 18, 2020Guru - Experienced User
- George2020Nov 18, 2020TutorSo after spending 2 hours on the phone with netgear customer support they have started an rma to replace this unit.
