BobStevenson
Nov 01, 2021Apprentice
R8000P Latest "breakware"...AGAIN!
Well, here we go again! Folks, do not update this doorstop to 1.4.2.84 without copying down on paper ALL your custom settings and stuff because you will likely need them after you update and hard res...
- Dec 31, 2021
I eventually had to rollback as well. Strange how I didn't have issues for nearly 6 weeks and suddenly, DNS resolution began faultering.
I tried re-flashing, restoring a back up .cfg created from the original branch, but the behavior continued. I then reset and tested upgrade to 1.4.2.84 from a unmodified flash of 1.4.1.68, same behavior. At this point, I recommend going back or holding at 1.4.1.68
Nov 02, 2021Guru - Experienced User
Try reverting back to what was working?
BobStevenson
Nov 02, 2021Apprentice
And yes Mr. Guru.....I know what I'm doing and what I am saying. I am not here for some months long discussion of try this, try that, blah, blah, blah. I am here to forewarn poor disfortunates that bought one of these too. Anyone that has ever flashed ANYTHING successfully as many times as I have, knows the procedure and foresteps to take to insure a sucessful flash provided everything is electrically sound and the firmware coder wasn't smoking dope while coding.
Good Luck to you also.
- njmolemanDec 17, 2021Guide
I'm not the type to pile on but Bob is right. I had not issues, but upgraded to the newest firmware for my R8000P as it stated it fixed security issues. and now I get this message from my browser all the time. this is from this forum went I wanted to reply to this post. I have struggled to check if the issue was with browsers, my security, etc. but all comes back to this firmware update.
- FURRYe38Dec 17, 2021Guru - Experienced User
What FW version had you been using prior to the update?
- BobStevensonDec 17, 2021ApprenticeThat screen you are getting in your browser is BAD FIRMWARE! Revert back to previous fw and it will work as designed. As for the “questions” READ READ READ! Modem is set to PASS-THROUGH. If you connect straight to the modem bypassing the router, all is fine with the modem. Problem is dope smoking coders and ZERO NADA ZILCH BETA TESTING on new releases and management PUSHING for a release! Tired of being fleeced by these “reputable” companies with less that average products and, like the testing, ZERO NADA ZILCH SUPPORT!!
- shadowsportsDec 17, 2021Hero
Greetings,
I've been running v1.4.2.84_1.3.42 since November 1st. Its stable. No performance issues here.
I do routinely make a back up of my config before upgrading (manually) and then another after the update, but haven't had any issues. I also have customized settings everywhere.
There are still certain features like renaming attached devices, etc which I have abandoned because they have been broken for so long.
However, over all performance and stability (wired and wireless) is fine.
For the DNS Error above I would:
Flush my DNS cache
Ensure my DNS settings matched those of my ISP, Cisco Umbrella, Cloudflare, etc. I don't normally use public DNS but you can if you wish.
Verify my DNS is resolving correctly.
- BobStevensonDec 17, 2021ApprenticeAnd furthermore….if they have ANY issues with ANY ARRIS modems then there are A LOT of people with this brick having the same issues. It’s BAD FIRMWARE…period.
