BobStevenson
Nov 01, 2021Apprentice
R8000P Latest "breakware"...AGAIN!
Well, here we go again! Folks, do not update this doorstop to 1.4.2.84 without copying down on paper ALL your custom settings and stuff because you will likely need them after you update and hard res...
- Dec 31, 2021
I eventually had to rollback as well. Strange how I didn't have issues for nearly 6 weeks and suddenly, DNS resolution began faultering.
I tried re-flashing, restoring a back up .cfg created from the original branch, but the behavior continued. I then reset and tested upgrade to 1.4.2.84 from a unmodified flash of 1.4.1.68, same behavior. At this point, I recommend going back or holding at 1.4.1.68
Dec 17, 2021Guru - Experienced User
What FW version had you been using prior to the update?
njmoleman wrote:
I'm not the type to pile on but Bob is right. I had not issues, but upgraded to the newest firmware for my R8000P as it stated it fixed security issues. and now I get this message from my browser all the time. this is from this forum went I wanted to reply to this post. I have struggled to check if the issue was with browsers, my security, etc. but all comes back to this firmware update.
BobStevenson
Dec 17, 2021Apprentice
That screen you are getting in your browser is BAD FIRMWARE! Revert back to previous fw and it will work as designed. As for the “questions” READ READ READ! Modem is set to PASS-THROUGH. If you connect straight to the modem bypassing the router, all is fine with the modem. Problem is dope smoking coders and ZERO NADA ZILCH BETA TESTING on new releases and management PUSHING for a release! Tired of being fleeced by these “reputable” companies with less that average products and, like the testing, ZERO NADA ZILCH SUPPORT!!
