BobStevenson
Nov 02, 2021Apprentice
R8000P Latest "breakware"...AGAIN!
Well, here we go again! Folks, do not update this doorstop to 1.4.2.84 without copying down on paper ALL your custom settings and stuff because you will likely need them after you update and hard res...
- Jan 01, 2022
I eventually had to rollback as well. Strange how I didn't have issues for nearly 6 weeks and suddenly, DNS resolution began faultering.
I tried re-flashing, restoring a back up .cfg created from the original branch, but the behavior continued. I then reset and tested upgrade to 1.4.2.84 from a unmodified flash of 1.4.1.68, same behavior. At this point, I recommend going back or holding at 1.4.1.68
njmoleman
Dec 29, 2021Guide
As stated, nothing has changed except the firmware. And just to add on, the modem is a Netgear CM2050 and the provider is Xfinity. There has been no firmware update on the modem. the issue is for every computer on the LAN side including phones and tablets. BTW I'm a network admin. I have a test enviroment to that I run all updates through before rolling them out to production devices. I would hope that Netgear does the same, and this is somehow yet another fluke and not a "good enough" update.
shadowsports
Jan 01, 2022Hero
