BobStevenson
Nov 01, 2021Apprentice
R8000P Latest "breakware"...AGAIN!
Well, here we go again! Folks, do not update this doorstop to 1.4.2.84 without copying down on paper ALL your custom settings and stuff because you will likely need them after you update and hard res...
- Dec 31, 2021
I eventually had to rollback as well. Strange how I didn't have issues for nearly 6 weeks and suddenly, DNS resolution began faultering.
I tried re-flashing, restoring a back up .cfg created from the original branch, but the behavior continued. I then reset and tested upgrade to 1.4.2.84 from a unmodified flash of 1.4.1.68, same behavior. At this point, I recommend going back or holding at 1.4.1.68
JM-KO
Feb 01, 2022Aspirant
Have to agree with with Bob and what's been said.... having the same issues as others reported. Having to reload web pages multiple times,and other conenction issues. All occured after the update. Just rolled back and everything is working good again. Bad QC of the firmware upgrade.
JM
Feb 01, 2022Guru - Experienced User
"At this point, I recommend going back or holding at >1.4.1.68 "
