PromptCritical
Sep 24, 2024Aspirant
R8000P latest firmware 1.4.4.94_1.3.56
I see the latest firmware is 1.4.4.94_1.3.56a but I cannot find any release notes. Has anyone tried this load and seen if DHCP reservations work? I tried a previous one a while back and reservation...
Sep 24, 2024Guru - Experienced User
It doesn't.
- PromptCriticalSep 24, 2024Aspirant
So anything after 88 the DHCP reservations do not work? And of course radio silence from Netgear on the subject I bet.
- FURRYe38Sep 24, 2024Guru - Experienced User
Check your PM.
- PromptCriticalOct 06, 2024Aspirant
It appears the 1.4.4.94 firmware has fixed the DHCP reservation issue.
- FURRYe38Oct 06, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
