les101
Jul 13, 2021Aspirant
R8000P limiting wired connections
I've had my R8000P for well over one year without any issues. A couple of days ago it started limioting the number of wired connections I can have to 3 or 4. I have a TV, Computer, a wireless extensi...
les101
Jul 16, 2021Aspirant
Router firmware V1.4.1.68_1.3.28
I am trying to plug in TV, Computer, Wireless Extender directly (3 ports of 4). The 4th port goes to a NetgearGS605 v4 switch. On that switch is a TV, DVD player, TiVo Box. Now depending on how a plug them in I can get 4 sometimes 5 to show up, but never all 6. So what happens is it seems like the 4 ports on the Nighthawk only allow me 3 connections. If it connects to the Netgear switch then all 3 of those devices show. I never get a partial on the switch (its 3 or 0). I have moved the connections around on the router ports, as well as trhe sequence. It is always the last device.that doesn't connect. Plugging the last device in does not kick off an already connected device.
Jul 17, 2021Guru - Experienced User
You should be able to plug plenty of devices into it if you're using a switch. I've used over 20 on varies routers without issues.
Have you tried a simple factory reset and reinstall on the r8000P?
If you have another switch and you go router----switch(with devices)-----switch(rest of devices) and only have the switch hardwired into the router, does it work? Just trying to figure out if there's a bad port on the router/switch
